The DIR9001 can decode the biphase signal format which is specified in one of the following standards. Generally, these following standards may be called Sony/Philips digital interface format (S/PDIF) or AES/EBU. • IEC60958 (revised edition of former IEC958) • JEITA CPR-1205 (revised edition of former EIAJ CP-1201, CP-340) • AES3 • EBU tech3250 The sampling frequency range and data word length which DIR9001 can decode is as follows: • Sampling frequency range is 28 kHz to 108 kHz. • Maximum audio sample word length is 24-bit. Note of others about the biphase input signal. • The capture ratio of the built-in PLL complies with level III of sampling frequency accuracy (±12.5%), which is specified in IEC60958-3. • The jitter tolerance of the DIR9001 complies with IEC60958-3. • The PLL may also lock in outside of the specified sampling-frequency range, but extended range is not assured. Notice about the signal level and transmission line of the biphase input signal. • The signal level and the transmission line (optical, differential, single-ended) are different in each standard. • The biphase input signal is connected to the RXIN pin of the DIR9001. • The RXIN pin has a 5-V tolerant TTL-level input. • An optical receiver module (optical to electric converter) such as TOSLINK, which is generally used in consumer applications, is connected directly to the RXIN pin without added external components. • The output waveform of the optical receiver module varies depending on the characteristics of each product type, so a dumping resistor or buffer amplifier might be required between the optical receiver module output and the DIR9001 input. Careful handling is required if the optical receiver module and the DIR9001 are separated by a long distance. • The DIR9001 needs an external amplifier if it is connected to a coaxial transmission line. • The DIR9001 needs an external differential to single-ended converter, attenuator, etc., for general consumer applications if non-optical transmission line is used.
Обновлено: 19.02.2021 в 22:55 | Просмотров: 1 232 |
Похожие статьи
STA339BWS - цифровой усилитель 2х20 Вт (Arduino)
S/PDIF (Sony/Philips Digital Interface) – распространенный и стандартизированный интерфейс, предназначенный для передачи цифрового звука между доступными компонентами, звуковыми картами, ресиверами и аудиоаппаратурой. I2S — стандарт интерфейса электрической последовательной шины, использующийся для соединения цифровых аудиоустройств. Применяется для передачи PCM-аудиоданных между интегральными схемами в электронном устройстве. Шина I2S передает по разным линиям сигналы синхронизации и сигналы...
ЦАП на DIR9001 + PCM5102A
Бюджетный внешний ЦАП на DIR9001 + PCM5102A состоит из простых и недорогих компонентов, прост в сборке. Ресивер S/PDIF собран на ИМС DIR9001, так как вход DIR9001 имеет вход уровня TTL, сигнал S/PDIF подается через преобразователь интерфейса MAX485. ЦАП собран на ИМС PCM5102A с пассивным ФНЧ настроенным на частоту 153 кГц. С выхода ЦАП звуковой сигнал (AUX) может непосредственно подаваться на наушники (32 Ом). Ресивер поддерживает следующие форматы: 24-Bit I2S 24-Bit...
DAC TDA1543 + DIR9001 + PT2259 (Arduino)
Внешний ЦАП состоит из недорогих и доступных компонентах, ресивер S/PDIF на базе DIR9001, ЦАП на TDA1543, регулятор громкости выполнен на PT2259. Так как вход DIR9001 имеет вход уровня TTL, сигнал S/PDIF подается через преобразователь интерфейса MAX485. Цифровой регулятор громкости PT2259 под управлением Arduino имеет 79 шагов уровней громкости, режим MUTE, управление громкостью осуществляется при помощи энкодера ky-040 (модуль), кнопка энкодера используется для активации режима MUTE. Уровень...
Theme Authenticity Checker (TAC) — избавляемся от скрытых и рекламных ссылок
Устанавливая бесплатный шаблон будьте готовы к тому, что в нем могут быть скрытые и рекламные ссылки. Так как шаблон бесплатный авторы этих шаблонов оставляют индексируемые ссылки на свои сайты и рекламные объявления. Нахождение этих ссылок нежелательно для Вашего сайта, от них необходимо избавится. Для это цели существует плагин Theme Authenticity Checker (TAC). Суть плагина в том, что н просматривает код шаблонов и выявляет скрытие ссылки. Для установки плагина Theme Authenticity...
Ремонт жк монитора samsung - модель S24A300BL / Repair the LCD monitor Samsung
В этом видео описывается дефект монитора Samsung S24A300BL / Repair the LCD monitor Samsung, неисправность проявляется следующим образом, когда вы подключаете монитор к сети электропитания у вас по экрану начинает перемещаться надпись проверьте кабель. Ремонт монитора Samsung S24A300BL заключается в прошивке на программаторе микросхемы Flash памяти W25X40AV прошивкой для монитора Samsung S24A300BL. Прошивка Samsung S24A300BL для программатора: http://yadi.sk/d/Oo1Sdx8Y4mcbE
