The WM8804 is a high performance consumer mode S/PDIF transceiver with support for 1 received channel and 1 transmitted channel. A crystal derived, or externally provided high quality master clock is used to allow low jitter recovery of S/PDIF supplied master clocks. Generation of all typically used audio clocks is possible using the high performance internal PLL. A dedicated CLKOUT pin provides a high drive clock output. A pass through option is provided which allows the device simply to be used to clean up (de-jitter) the received digital audio signals. The device may be used under software control or stand alone hardware control modes. In software control mode, both 2-wire with read back and 3-wire interface modes are supported. Status and error monitoring is built-in and results can be read back over the control interface, on the GPO pins or streamed over the audio data interface in ‘With Flags’ mode (audio data with status flags appended). The audio data interface supports I2 S, left justified, right justified and DSP audio formats of 16-24 bit word length, with sample rates from 32 to 192ks/s. The device is supplied in a 20-lead Pb-free SSOP package.
Обновлено: 19.02.2021 в 22:43 | Просмотров: 1 166 |
Похожие статьи
PT2322
PT2322 is a 6-Channel Audio Processor IC utilizing CMOS Technology specially designed for audio applications. 6-channel individual input, 6-channel master volume control, 6-channel individual volume trim control, 3-band tone control (treble, middle, and bass), mute function, 3D effect function, tone defeat function are all built into a single chip having the highest performance and reliability with the least components. Furthermore, the pin assignments and application circuit are optimized for...
AK4396
The AK4396 is a high performance stereo DAC for the 192kHz sampling mode of DVD-Audio including a 24bit digital filter. Using AKM's multi bit architecture for its modulator the AK4396 delivers a wide dynamic range while preserving linearity for improved THD+N performance. The AK4396 has full differential SCF outputs, removing the need for AC coupling capacitors and increasing performance for systems with excessive clock jitter. The AK4396 accepts 192kHz PCM data and 1-bit DSD data, ideal for a...
TDA7303
The TDA7303 is a volume, tone (bass and treble) balance (left/right) and fader (front/rear) processor for quality audio applications in car radio, Hi-Fi and portable systems. Selectable input gain and external loudness function are provided. Control is accomplished by serial I2C bus microprocessor interface. The AC signal setting is obtained by resistor networks and switches combined with operational amplifiers. Thanks to the used bipolar/CMOS technology, low distortion, low noise and low DC...
DIR9001
The DIR9001 can decode the biphase signal format which is specified in one of the following standards. Generally, these following standards may be called Sony/Philips digital interface format (S/PDIF) or AES/EBU. • IEC60958 (revised edition of former IEC958) • JEITA CPR-1205 (revised edition of former EIAJ CP-1201, CP-340) • AES3 • EBU tech3250 The sampling frequency range and data word length which DIR9001 can decode is as follows: • Sampling frequency range is 28 kHz to 108 kHz. • Maximum...
R2S15900SP
The R2S15900SP is an optimum audio signal processor IC for TV. It has a 5ch input selector, surround/pseudo stereo, tone control(2band), output gain control and 2ch master volume. It can control all of these functions with I2 C bus. r2s15900sp.pdf Ваш браузер не поддерживает фреймы
AK4396
TDA7303
DIR9001
R2S15900SP
