The TDA7389A is an AB class audio power amplifier, packaged in Flexiwatt 27 designed for high end car radio applications. Based on the fully complementary PNP/NPN configuration the TDA7389A allows a rail to rail output voltage swing with no need of bootstrap capacitors.
tda7389a.pdf
