The R2A15908SP is an optimum audio signal processor IC for TV. It has a 5ch input selector with mono switch, surround, tone control (2band), input gain control and 2ch master volume. It can control all of these functions with I2C bus.
Обновлено: 22.02.2021 в 11:58 | Просмотров: 1 170 |
Похожие статьи
TDA7303
The TDA7303 is a volume, tone (bass and treble) balance (left/right) and fader (front/rear) processor for quality audio applications in car radio, Hi-Fi and portable systems. Selectable input gain and external loudness function are provided. Control is accomplished by serial I2C bus microprocessor interface. The AC signal setting is obtained by resistor networks and switches combined with operational amplifiers. Thanks to the used bipolar/CMOS technology, low distortion, low noise and low DC...
PT2322
PT2322 is a 6-Channel Audio Processor IC utilizing CMOS Technology specially designed for audio applications. 6-channel individual input, 6-channel master volume control, 6-channel individual volume trim control, 3-band tone control (treble, middle, and bass), mute function, 3D effect function, tone defeat function are all built into a single chip having the highest performance and reliability with the least components. Furthermore, the pin assignments and application circuit are optimized for...
R2S15900SP
The R2S15900SP is an optimum audio signal processor IC for TV. It has a 5ch input selector, surround/pseudo stereo, tone control(2band), output gain control and 2ch master volume. It can control all of these functions with I2 C bus. r2s15900sp.pdf Ваш браузер не поддерживает фреймы
AD7390/AD7391
The AD7390/AD7391 family of 10-bit and 12-bit voltageoutput digital-to-analog converters is designed to operate from a single 3 V supply. Built using a CBCMOS process, these monolithic DACs offer the user low cost, and ease-of-use in single-supply 3 V systems. Operation is guaranteed over the supply voltage range of 2.7 V to 5.5 V consuming less than 100 µA making this device ideal for battery operated applications. The full-scale voltage output is determined by the external reference input...
Оптимизация производительности веб-приложений на JavaScript: лучшие практики и инструменты
Производительность веб-приложений играет ключевую роль в обеспечении положительного пользовательского опыта. Медленные сайты раздражают пользователей и негативно влияют на конверсию и удержание аудитории. В этой статье мы рассмотрим лучшие практики и инструменты для оптимизации производительности веб-приложений на JavaScript, дополнив их примерами и подробностями. 1. Минимизация и сжатие кода Уменьшение размера файлов JavaScript — первый шаг к повышению производительности. Это достигается...
PT2322
R2S15900SP
AD7390/AD7391
